Cisco Unified Wireless IP Phone 8821, World Mode
Quicklinx: CFQ4WS00 Mfr#: CP-8821-K9=
£491.82 ex VAT
£590.18 inc VAT
The 8821 is specifically designed for workers whose roles are in more rigorous, industrial settings. Examples of ideal use cases include nurses and doctors in healthcare, operations and engineering staff in manufacturing, customer service representatives in retail, service staff such as maids in hospitality, and workers on rigs in the oil and chemical industries.
While the 8821 is sleek and lightweight, the design is hardened for users. It is Ingress Protection standard (IP67) rated and is sealed for protection against dust and immersion in water. The device is also MIL-STD-810G tested, with a dozen drops onto concrete from heights of up to 6 feet (1.8 m), to help ensure shock resistance and avoid breakage if dropped.
The 8821 enhances security and simplifies configuration management. Stronger encryption is supported for certificate management and policy enablement with the support of Secure Hash Algorithm 2 (SHA-2). Simple Certificate Enrollment Protocol (SCEP) eases IT administration by enabling automatic certificate management on the device.
End users will enjoy a larger, higher-resolution color display and a user experience that is common with Cisco IP Phone 8800 Series desk phones. In addition, roaming between access points within the campus will support more seamless voice communications with the 8821's support of Fast Transition (802.11r). This protocol was specifically designed for mobile voice over IP (VoIP) communications devices within Wi-Fi networks.
The 8821 supports Cisco and/or third-party XML applications such as push-to-talk.
  • Enhanced mobility
    The Cisco IP Phone 8821 is designed for mobility, offering a cordless solution with IEEE 802.11a/b/g/n/ac (Wi-Fi) connectivity. This feature allows users to move freely around their workspace without losing call quality or connectivity.
  • Clear call quality
    Equipped with a range of voice codecs including G.711a, G.711u, G.722, G.729a, G.729ab, and iLBC, the Cisco IP Phone 8821 ensures clear voice communication. Whether in a noisy office or a quiet room, the call quality remains consistent.
  • Versatile connectivity
    This device not only supports Bluetooth for wireless headset connection but also includes a USB port and a mini-phone 3.5 mm connector for headphones. These connectivity options offer flexibility in how calls are received and made, catering to the user's preference.
  • Robust call management
    With features like call forwarding, call hold, call waiting, and caller ID, managing calls is seamless and efficient. The phone supports up to 6 lines, making it suitable for handling high volumes of calls with ease.
  • Intuitive user experience
    A 2.4-inch color LCD display with a resolution of 240 x 320 pixels provides a clear and vibrant interface for users. The display, combined with the voice message waiting indicator and volume control, enhances the overall user experience.
Cisco IP Phone 8821 - cordless extension handset - with Bluetooth interface
Cordless extension handset - with Bluetooth interface
Total Number of Wireless Handsets
1
Cordless Phone Standard
VoIP Protocols
SIP
Voice Codecs
G.722, G.729a, G.729ab, G.711u, G.711a, iLBC
Lines Supported
6 lines
Speakerphone
Call Services
Caller ID, Call Waiting, Call Forwarding, Call Hold
Display
LCD display - colour
1-year warranty
Integrated Components
Bluetooth interface
1
Phone Features
Wireless Interface Provided
Bluetooth
Call Services
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Indicators
Voice message waiting indicator
Additional Functions
Intercom
IP Telephony
VoIP
VoIP Protocols
SIP
Voice Codecs
Lines Supported
6 lines
Security
TLS
Display
Diagonal Size
2.4"
Display Resolution
240 x 320 pixels
USB , Headphones / mini-phone 3.5mm
Dimensions & Weight (Base)
5.6 cm
1.7 cm
13.2 cm
163 g
1-year warranty
Brand: Cisco
