Cisco Small Business SG300-28SFP Switch L3 Managed 24 Gigabit
Quicklinx: C7BZWS00 Mfr#: SG300-28SFP-K9-UK
The Cisco 300 series provides a reliable foundation for your business network. This switch delivers the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 300 series provides the ideal combination of affordability and capabilities for small businesses, and helps you create a more efficient, better-connected workforce.
The Cisco 300 series provides optimal flexibility to create exactly the right network foundation for your business. However, unlike other small business switching solutions that provide managed network capabilities only in the costliest models, Cisco 300 series switch supports the advanced security management capabilities and network features you need to support business-class data, voice, security, and wireless technologies. At the same time, this switch is simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
  • High performance and reliability
    Cisco 300 series switch has been rigorously tested to deliver the high availability and performance you expect from a Cisco switch. The solution speeds up file transfer times and improve slow, sluggish networks, while keeping your vital business applications available and preventing costly downtime.
  • Strong security
    The Cisco 300 series switch provides a high level of security and gives you fine-grained control to safeguard your network from unauthorized users.
  • IP telephony support
    Cisco 300 series switch includes embedded QoS intelligence to prioritize delay-sensitive services such as voice and video, simplify unified communications deployments, and help ensure consistent network performance for all services.
  • Network-wide automatic voice deployment
    Using a combination of CDP, LLDP-MED, auto smart ports, and VSDP, customers can deploy an end-to-end voice network dynamically. The switch in the network automatically converges around a single voice VLAN and QoS parameters and then propagates them out to the phones on the ports where they are discovered.
  • Advanced network management capabilities
    As managed switches, the Cisco 300 series lets you use a variety of advanced features to control traffic over your network.
  • Optimal energy efficiency
    Cisco 300 series switch is designed with a variety of power-saving features. This switch optimizes power use to protect the environment and reduce energy costs, without compromising performance.
  • Peace of mind and investment protection
    Cisco 300 series switch offers the reliable performance, investment protection, and peace of mind you expect from a Cisco switch.
Cisco Small Business SG300-28SFP - switch - 26 ports - Managed - rack-mountable
Switch - 26 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 2 x combo Gigabit SFP
Performance
Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 41.67 Mpps
ACL rules: up to 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), STP Root Guard, Uni-Directional Link Detection (UDLD), fanless, DHCP relay, IP-MAC binding, Energy Efficient Ethernet, Class of Service (CoS), Generic Attribute Registration Protocol (GARP), 8MB packet buffer, GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 25.7 cm x 4.445 cm
3.34 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, link/activity
2 x 1000Base-T RJ-45 , 2 x console DB-9 management , 26 x 1000Base-X SFP
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
614,062 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
25.7 cm
4.445 cm
3.34 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
