Cisco Small Business Services Router - 4-port Switch
Quicklinx: 8DVTWS00 Mfr#: SRP521W-U-E-K9
  • IEEE 802.11n
Demand for managed services is expected to grow dramatically over the next four years, with small businesses - those with fewer than 100 employees - expected to make up more than half of this market opportunity. These companies may have complex IT needs but generally don't have the technical staff or expertise needed to keep up. They look to service providers for a flexible infrastructure and simplified management, along with better quality and reliability than they can achieve in-house. To meet this opportunity, service providers are transforming their networks, using services-ready platforms to deliver an array of profitable IP-based communications services.
Cisco SRP 500 Series Services Ready Platforms are flexible, cost-effective fixed-configuration customer premises equipment (CPE) with embedded intelligence to enable service providers to create, provision, and deploy premium revenue-generating services to small businesses on an as-needed basis. These platforms will help enable service providers to deliver differentiated, converged service offers that increase bandwidth usage and average revenue per user while reducing customer churn.
  • Embedded intelligence
    Embedded intelligence supports concurrent, premium revenue-generating services such as voice, data, security, and applications. Service providers can easily create and provision a variety of service offerings, adding or removing them remotely as their customers' needs change.
  • Industry-leading SIP stack
    Industry-leading SIP stack delivers an advanced implementation of standard voice coding algorithms for clear, high-quality voice under diverse network conditions, along with support for common telephony features such as voice mail, fax, and interactive voice response systems.
  • Interoperability
    Interoperability with industry-leading soft switches and voice gateways enable service providers to deploy highly efficient, scalable end-to-end multi-service networks.
  • Standards-based provisioning
    Standards-based provisioning, with support for TR-069, TR-104, and XML, that reduces operating expenses by enabling zero touch deployments, eliminating the need for highly skilled technicians and costly truck rolls to deploy new services.
  • Compact design
    Compact design integrates voice, data, switching, wireless, security, and application support in a desktop device that is ideal for simple, space-saving small business deployments.
Cisco Small Business SRP521W-U - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Virtual interfaces (VLANs): 5 , IPSec VPN tunnels: 5
Network / Transport Protocol
TCP/IP, UDP/IP, L2TP, ICMP/IP, PPPoE
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, static IP routing, IGMPv3, GRE
Remote Management Protocol
SNMP 1, SNMP 2, HTTP, HTTPS, TFTP
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP v2
Telephony Interfaces
2 phone (FXS), 1 line (FXO)
Auto-sensing per device, NAT support, ARP support, VLAN support, reverse NAT support, auto-uplink (auto MDI/MDI-X), Syslog support, traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, DiffServ support, MAC address filtering, VPN passthrough, SNTP support, Low-latency queuing (LLQ), Weighted Fair Queuing (WFQ), IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, event log, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, DNS proxy, port forwarding
IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
AC 120/230 V
Enclosure Type
Desktop
Wireless, wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, ETSI, CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, AS/NZS 60950-1, RSS-210, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, CS-03, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, FCC CFR47 Part 15, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 386
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Power, phone, WLAN, WAN, LAN, USB
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP v2
Voice Codecs
G.711, G.723.1, G.729ab, G.726, T.38
IP Telephony Features
Echo cancellation, comfort noise generation (CNG), voice activity detection (VAD), Caller ID, call waiting, call hold, call transfer, silence suppression, DTMF generation/detection
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , Phone line: 1 x FXO - RJ-11 , Phone line: 2 x FXS - RJ-11 , USB 2.0: 1 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
1
Gain Level
2.2 dBi
External power adapter
AC 120/230 V
1 x network cable , 1 x phone cable
Software Included
Drivers & Utilities
5 - 95% (non-condensing)
