The Cisco 500 series stackable managed switch provides the ideal technology foundation for demanding business networks. It offers the perfect mix of advanced features needed to ensure the availability of critical applications. Now you can protect business information and provide a solid foundation for your current business applications, as well as those you are planning for the future-all in a package you can afford.
High reliability and resiliency
Keep your network up and running with advanced redundancy and availability features that reduce downtime and improve network resiliency so your business never slows down. -
Strong security
Advanced security features protect your business data and keep unauthorized users off your network. -
Power-efficient
A variety of power-saving features across all models provide one of the industry's most extensive energy-efficient switching portfolios. -
Simplified network setup and operations
Intuitive browser-based tools, auto-configuration and discovery, and true stacking make theses switches easy to use and manage, and simplify day-to-day network operations.
- Cisco Small Business SG500-52MP - switch - 52 ports - Managed - rack-mountable
- Switch - 52 ports - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 740 W
- Performance
- Forwarding performance (64-byte packet size): 77.38 Mpps , Switching capacity: 120 Gbps , Stateful throughput: 5 Gbps
- Capacity
- IPv4 routes: 2048 , IPv6 routes: 2048 , ACL rules: 2048
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
- Flow control, Layer 2 switching, PoE, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, DHCP server, MLD snooping, DAI, PoE+, reset button, STP Root Guard, UDLD, LACP support, LLDP support, DHCP relay, Energy Efficient Ethernet, GVRP, CoS, SP, GARP, 16MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 35 cm x 4.4 cm
- 5.6 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 740 W
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Max Units In A Stack
- 8
- Routing Protocol
- Static IP routing
- Authentication Method
- RADIUS, TACACS+
- Processor
- X ARM: 800 MHz
- RAM
- 256 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 48 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP , 1 x serial DB-9
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- MTBF
- 186,968 hour(s)
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- Europe
- 44 cm
- 35 cm
- 4.4 cm
- 5.6 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.76 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
