Get high performance, advanced programmability, and wire-rate Layer 2 and 3 switching based on the Cisco NX-OS operating system. The 31108PC-V SFP+ is a 48-port 1/10-Gbps switch with 40/100-Gbps uplinks. It supports DevOps toolsets, and offers mobility and scale for service and cloud providers. This compact, top-of-rack (ToR) switch is ideal for building cost-effective, power-efficient data centers.
Robust security
Equipped with AES encryption and multiple authentication methods including MS-CHAP, RADIUS, Secure Shell v.2 (SSH2), and TACACS+, the Cisco Nexus 31108PC-V ensures secure network access and data protection. -
High performance
With a switching capacity of 2.8 Tbps and forwarding performance of 1.4 Bpps, coupled with a low latency of 650 ns, this switch is designed to handle intensive data traffic efficiently. -
Advanced networking
Supports a wide range of networking standards such as IEEE 802.1Q, IEEE 802.3ad (LACP), and advanced features like Access Control List (ACL) support, VLAN support, and Virtual PortChannel (vPC) technology, making it versatile for various network configurations. -
Enhanced manageability
Manageable via CLI, SNMP, RMON, and more, the Cisco Nexus 31108PC-V offers comprehensive remote management capabilities, facilitating easier network administration and monitoring. -
Flexible connectivity
Features 48 SFP+ ports and additional support for serial (RS-232) and USB connections, providing a wide range of connectivity options for different network requirements.
 - Cisco Nexus 31108PC-V - switch - 48 ports - Managed - rack-mountable
 - Switch - 48 ports - L3 - Managed
- Enclosure Type
 - Front to back airflow rack-mountable 1U
- Subtype
 - 10 Gigabit Ethernet
- Ports
 - 48 x SFP+ + 6 x QSFP+
- Performance
 - Switching capacity: 2.8 Tbps , Forwarding performance: 1.4 Bpps , Latency: 650 ns
- Capacity
 - Virtual interfaces (VLANs): 4096 , Multiple Spanning Tree Protocol instances: 64 , Rapid Spanning Tree Protocol instances: 512 , ACL entries (ingress): 16000 , ACL entries (egress): 1000
- MAC Address Table Size
 - 288K entries
- Jumbo Frame Support
 - 9216 bytes
- Routing Protocol
 - OSPF, RIP-2, IGMPv2, HSRP, VRRP, OSPFv2, PIM-SM, IGMPv3, MSDP, ECMP, CIDR
- Remote Management Protocol
 - SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, SSH-2, CLI
 - DHCP support, BOOTP support, trunking, VLAN support, Syslog support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, Jumbo Frames support, EIGRP Stub Routing, URPF, UDLD, NTP time synchronisation, vPC technology, PTP, VXLAN, EVPN
 - IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3ba, IEEE 1588-2008
- Power
 - AC 120/230 V (50/60 Hz)
- Power Redundancy
 - 43.9 cm x 50.5 cm x 4.4 cm
 - 9.3 kg
 - 1-year warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Capacity
 - 288K entries
 - 9216 bytes
- Routing Protocol
- Encryption Algorithm
 - AES
- Authentication Method
 - RADIUS, TACACS+, MS-CHAP, Secure Shell v.2 (SSH2)
- Flash Memory
 - 16 GB
 - 48 x SFP+ , 1 x 1000Base-T RJ-45 management , 6 x QSFP+ , 1 x serial (RS-232) , 1 x USB
- Power Device
 - Internal power supply - hot-plug
- Installed Qty
 - 2
- Max Supported Qty
 - 2
- Power Redundancy
- Power Redundancy Scheme
 - 1+1
- Voltage Required
 - CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, GB 4943, Directive 2004/108/EC, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class A, KN24, KN22 Class A, EN 55022 Class A, EN 300 386
- Software Included
 - Cisco NX-OS Layer 3 Base Services
 - 43.9 cm
 - 50.5 cm
 - 4.4 cm
 - 9.3 kg
 - Limited warranty - advance parts replacement - 1 year - response time: 10 days
 - 0 °C
 - 40 °C
 - 10 - 85% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 95% (non-condensing)
                        Cisco 10GBASE-SR SFP Module | In Stock | £189.58 |
                        Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £117.44 |
                        Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £78.27 |
                        Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m | In Stock | £64.13 |
                        Cisco SFP+ Transceiver Module | In Stock | £435.97 |
                        Cisco SFP+ Copper Twinax Cable 2m - Brown | In Stock | £103.22 |
                        Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC | In Stock | £1,565.79 |
                        Cisco 1000BASE-T SFP Transceiver | In Stock | £185.35 |
