The Cisco 10GBASE SFP+ modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
- Cisco - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC/PC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- 1.3 cm x 5.7 cm x 0.9 cm
- 75 g
- 90 days warranty
- Designed For
- Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter; Nexus 5010
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 300 m
- IEEE 802.3ae
- 1 x Ethernet 10GBase-SR - LC/PC multi-mode x 2
- Compatible Slots
- 1 x SFP+
- 1.3 cm
- 5.7 cm
- 0.9 cm
- 75 g
- Limited warranty - 90 days
- 0 °C
- 70 °C
- Designed For
- Cisco Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter , Cisco Nexus 5010
|  | Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £111.13 |
|  | Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £73.75 |
|  | Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m | In Stock | £63.84 |
|  | Cisco SFP+ Copper Twinax Cable 2m - Brown | In Stock | £103.22 |
