Cisco SFP+ Copper Twinax cables are suitable for very short distances. Twinax cables offer a highly cost-effective way to connect within racks and across adjacent racks.
Efficient connectivity
The Cisco SFP+ Copper Twinax Cable is designed for high-speed data transmission, featuring twinaxial cable technology that ensures a reliable connection between devices. With both left and right connectors being SFP+, it seamlessly integrates with compatible Cisco devices, including switches and network management devices. -
Durable design
Crafted with a 30 American Wire Gauge (AWG), this direct attach cable is built for durability and long-term use. Its robust design supports the demands of daily operations, making it an ideal choice for establishing secure and stable network connections.
- Cisco SFP+ Copper Twinax Cable - direct attach cable - 1 m
- Direct attach cable
- Technology
- Twinaxial
- Cable Length
- 1 m
- Connector
- SFP+
- Connector (Second End)
- SFP+
- Designed For
- 250 Series; Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, ESS9300; Nexus 93180, 9336, 9372; UCS 6140, C4200
- Network Cable Type
- Technology
- Twinaxial
- American Wire Gauge (AWG)
- 30
- Cable Length
- 1 m
- Connector
- SFP+
- SFP+
- Designed For
- Cisco 250 Series SG250X-48P , Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, ESS9300 Embedded Series , Cisco Nexus 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco UCS 6140XP Fabric Interconnect, C4200 Rack Server Chassis
