Cisco 1000BASE-T SFP Transceiver
Quicklinx: CZV1WS00 Mfr#: GLC-TE=
25 In Stock
£179.28 ex VAT
£215.13 inc VAT
Cisco SFP (mini-GBIC) transceiver module with Gigabit Ethernet for Cisco 20-port 1-Gigabit; Nexus 7700 F3-Series, 9372PX, 9396PX
  • Efficient connectivity
    The Cisco SFP (mini-GBIC) transceiver module offers wired connectivity technology, ensuring a stable and efficient link for network communications. Its Gigabit Ethernet data link protocol supports a data transfer rate of 1 Gbps, making it ideal for high-speed data transmission needs.
  • Versatile temperature range
    Designed to operate in a wide range of temperatures, this module can function optimally in environments as cold as -5°C and as hot as 85°C. This feature ensures reliable performance in various operating conditions.
  • Easy integration
    With its plug-in module form factor and hot swap module replacement feature, this transceiver module can be easily integrated into existing network setups without significant downtime, facilitating seamless upgrades and maintenance.
Cisco - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter; Catalyst ESS9300 Embedded Series; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
Full duplex capability, hot swap module replacement
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45
-5 °C
85 °C
Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter , Cisco Catalyst ESS9300 Embedded Series , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
Brand: Cisco
