Cisco Nexus 31108-VXLAN 48 X SFPAN
Quicklinx: DPWVWS00 Mfr#: N3K-C31108PC-V
Type: 10 Gigabit Ethernet
Ports: 48
Managed: Yes
£8,084.46 ex VAT
£9,701.35 inc VAT
Get high performance, advanced programmability, and wire-rate Layer 2 and 3 switching based on the Cisco NX-OS operating system. The 31108PC-V SFP+ is a 48-port 1/10-Gbps switch with 40/100-Gbps uplinks. It supports DevOps toolsets, and offers mobility and scale for service and cloud providers. This compact, top-of-rack (ToR) switch is ideal for building cost-effective, power-efficient data centers.
  • Robust security
    Equipped with AES encryption and multiple authentication methods including MS-CHAP, RADIUS, Secure Shell v.2 (SSH2), and TACACS+, the Cisco Nexus 31108PC-V ensures secure network access and data protection.
  • High performance
    With a switching capacity of 2.8 Tbps and forwarding performance of 1.4 Bpps, coupled with a low latency of 650 ns, this switch is designed to handle intensive data traffic efficiently.
  • Advanced networking
    Supports a wide range of networking standards such as IEEE 802.1Q, IEEE 802.3ad (LACP), and advanced features like Access Control List (ACL) support, VLAN support, and Virtual PortChannel (vPC) technology, making it versatile for various network configurations.
  • Enhanced manageability
    Manageable via CLI, SNMP, RMON, and more, the Cisco Nexus 31108PC-V offers comprehensive remote management capabilities, facilitating easier network administration and monitoring.
  • Flexible connectivity
    Features 48 SFP+ ports and additional support for serial (RS-232) and USB connections, providing a wide range of connectivity options for different network requirements.
Cisco Nexus 31108PC-V - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x SFP+ + 6 x QSFP+
Performance
Switching capacity: 2.8 Tbps , Forwarding performance: 1.4 Bpps , Latency: 650 ns
Virtual interfaces (VLANs): 4096 , Multiple Spanning Tree Protocol instances: 64 , Rapid Spanning Tree Protocol instances: 512 , ACL entries (ingress): 16000 , ACL entries (egress): 1000
MAC Address Table Size
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
OSPF, RIP-2, IGMPv2, HSRP, VRRP, OSPFv2, PIM-SM, IGMPv3, MSDP, ECMP, CIDR
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, SSH-2, CLI
DHCP support, BOOTP support, trunking, VLAN support, Syslog support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, Jumbo Frames support, EIGRP Stub Routing, URPF, UDLD, NTP time synchronisation, vPC technology, PTP, VXLAN, EVPN
IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3ba, IEEE 1588-2008
Power Redundancy
43.9 cm x 50.5 cm x 4.4 cm
9.3 kg
1-year warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
AES
Authentication Method
RADIUS, TACACS+, MS-CHAP, Secure Shell v.2 (SSH2)
Flash Memory
16 GB
48 x SFP+ , 1 x 1000Base-T RJ-45 management , 6 x QSFP+ , 1 x serial (RS-232) , 1 x USB
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, GB 4943, Directive 2004/108/EC, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class A, KN24, KN22 Class A, EN 55022 Class A, EN 300 386
Software Included
Cisco NX-OS Layer 3 Base Services
43.9 cm
50.5 cm
4.4 cm
9.3 kg
Limited warranty - advance parts replacement - 1 year - response time: 10 days
10 - 85% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
DPWV Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £117.44
DPWV Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £78.27
DPWV Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £64.13
DPWV Cisco SFP+ Transceiver Module In Stock £435.97
DPWV Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £103.22
DPWV Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,565.79
DPWV Cisco 1000BASE-T SFP Transceiver In Stock £185.35
Ports: 48
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
