Cisco Key Expansion Module for IP Phone 8851, 8861
Quicklinx: BZ4DWS00 Mfr#: CP-BEKEM=
This key extension module has increased productivity by its high speed. This product delivers a rich-media experience across any workspace securely and with high possible quality. Cisco IP Phone 8800 key expansion module extends the capabilities of Cisco IP models with additional buttons and a color LCD display.
  • Large LCD display
    Cisco IP Phone 8800 key expansion module allows for quick and easy identification of associated buttons. You can adjust the brightness of the individual key-expansion-module LCD according to your preference.
  • Extended possibilities
    The primary function of the Cisco IP Phone 8800 key expansion module is to provide additional keys for directory numbers, speed dial as well as for programmable feature keys.
  • Comfortable use
    Two illuminated page buttons below the Cisco IP Phone 8800 key expansion module display allow you to shift between the first and second page of 18 buttons, providing access to all 36 keys.
Cisco - key expansion module for VoIP phone
Key expansion module
Intended For
VoIP phone
13.1 cm x 4 cm x 22.9 cm
489 g
1-year warranty
IP Phone 8851, 8861
Intended For
VoIP phone
Display
LCD display
13.1 cm
4 cm
22.9 cm
489 g
1 year
Cisco IP Phone 8851, 8861
