Cisco Cisco ADSL Secure Router
Quicklinx: 7M4XWS00 Mfr#: SR520W-ADSL-K9
More than ever, you rely on technology to help you keep pace with competitors. You depend on your network to keep you connected to the people you do business with every day, from customers to suppliers and business partners. Yet when you have a small dedicated networking staff, it can be difficult to manage your network and make sure it's well protected from security breaches. To be successful, you need a complete network solution that delivers the security and rich features you need, yet is affordable and easy to use.
The Cisco 520 Series Secure Router combines Internet access, advanced security, and virtual private network (VPN) access, all in a single easy-to-use device. A component of the Cisco smart business communications system - a complete set of advanced voice, data, security, and wireless networking products designed specifically for small and medium-sized businesses-the Cisco 520 Series Secure Router brings together multiple technologies to help you lower costs, improve network security, and simplify network management.
The Cisco 520 Series Secure Router is a family of fixed-configuration routers that deliver the connectivity, performance, and security you are looking for to support your business.
Part of the Cisco smart business communications system, the Cisco 520 Series Secure Router is ideal for securely connecting small offices to the Internet or to other company offices.
  • Built-in advanced security
    The Cisco 520 Series Secure Router includes in-depth security features to help protect your most critical business information and communications. A Cisco IOS firewall with application layer inspection offers threat control by helping to protect the network from unauthorized users and minimizes threats on web traffic, outgoing applications, and email by blocking unwanted activity. In addition, built-in encryption using IPSec, Triple Data Encryption Standard (3DES), and Advanced Encryption Standard (AES) lets remote employees connect to the network securely using SSL VPN and Cisco Easy VPN. And advanced security features such as URL filtering blocks access to undesirable websites and inline IPS shields the network from worms and provides sophisticated threat defense.
  • Increased performance to run concurrent services
    The Cisco 520 Series Secure Router offers broadband performance while simultaneously running services like firewall, intrusion prevention, VPN encryption, and wireless networking. There is no need to purchase additional security and wireless products. Managing a single all-in-one router is easier and less expensive than managing multiple network devices.
  • Built-in managed switch
    For companies with network devices, such as printers or servers, that need to be connected, the Cisco 520 Series Secure Router includes an integrated managed switch. You can set up one port on the switch as a network demilitarized zone (DMZ) to add an additional layer of security to your network. The switch also supports VLANs to let you securely separate traffic on your office network.
  • Simplified deployment and management
    Cisco configuration assistant makes it easy to install the Cisco 520 Series Secure Router and manage it from a central point. You can set up the router in minutes using the intuitive graphic interface, without having to learn command-line interface. After the network is up and running, Cisco configuration assistant can generate status reports, synchronize passwords, and upgrade software across all of your Cisco network devices, reducing the time your staff must devote to network deployment and configuration.
  • Quality of service (QoS)
    The Cisco 520 Series Secure Router features the QoS intelligence you need to support crisp delivery of rich voice and video applications. Sophisticated QoS lets you prioritize networking traffic for smooth performance, even with delay-sensitive applications such as real-time voice and video.
  • Easy integration into the Cisco smart business communications system
    The Cisco 520 Series Secure Router was designed to integrate into a complete system of advanced voice, data, security, and wireless networking products designed specifically for small and medium-sized businesses. You can quickly deploy and configure all components in the Cisco smart business communications system, including the Cisco 520 Series Secure Router, using Cisco configuration assistant.
Cisco 520 Series Secure - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 10
Network / Transport Protocol
PPTP, ICMP/IP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS
Firewall protection, auto-sensing per device, DHCP support, NAT support, VPN support, PAT support, VLAN support, auto-uplink (auto MDI/MDI-X), traffic shaping, SPI, dynamic DNS server, MAC address filtering, IPv6 support, IPS, URL filtering, LLQ, CBWFQ, WFQ, WMM support, ACL support, QoS, IPSec passthrough, DHCP server
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
26.9 cm x 21 cm x 4.4 cm
1.4 kg
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 10
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, AES, TLS, PEAP, TTLS, TKIP, WPA2, WPA-PSK
Authentication Method
RADIUS, TACACS+, EAP-FAST
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC950, VCCI-II, EN55022 Class B, ICES-003 Class B, ACA TS001, AS/NZS 3260, FCC Part 68, CS-03, UL 1950 Third Edition, EN 60555-2, FCC CFR47 Part 15 B
RAM
128 MB (installed) / 128 MB (max)
Flash Memory
36 MB (installed) / 36 MB (max)
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , Management: 1 x console - RJ-45
Aerial
Aerial
External detachable
Gain Level
2.2 dBi
External power adapter - 26 Watt
26.9 cm
21 cm
4.4 cm
1.4 kg
10 - 85%
