Cisco 860VAE Series Integrated
Quicklinx: BTWGWS00 Mfr#: C867VAE-W-E-K9
  • IEEE 802.11n (draft 2.0)
£324.04 ex VAT
£388.84 inc VAT
An entry level member of the Cisco Integrated Services Router Generation 2 (ISR G2) family, the Cisco 867VAE Integrated Services Router offers connectivity to teleworkers and small branches.
  • Robust security
    Equipped with 10 IPSec VPN tunnels, the Cisco 867VAE offers a secure and reliable connection for transmitting sensitive data, ensuring your online activities remain private and protected.
  • Comprehensive connectivity
    This device boasts a variety of interfaces including Ethernet 10Base-T/100Base-TX for LAN and WAN connections, alongside an RJ-45 connector, providing versatile options for setting up and expanding your network.
  • Advanced networking capabilities
    With support for IPv6, NetFlow, and Class-Based Weighted Fair Queuing (CBWFQ), the Cisco 867VAE facilitates efficient data flow and network management, making it ideal for handling heavy traffic loads.
  • High-speed Internet access
    Featuring ADSL2+ and VDSL2 digital signaling protocols, the Cisco 867VAE delivers fast and reliable Internet access, ensuring smooth streaming, browsing, and downloading across your network.
  • Easy remote management
    Remote management protocols such as HTTP, HTTPS, SNMP 3, and SSH allow for convenient and secure configuration and monitoring of the device from anywhere, simplifying network administration tasks.
Cisco 867VAE - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 5-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
IPSec VPN tunnels: 10
Network / Transport Protocol
IPSec, PPPoE, PPPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, BGP, policy-based routing (PBR)
Remote Management Protocol
SNMP 3, HTTP, HTTPS, SSH
NAT support, VLAN support, auto-uplink (auto MDI/MDI-X), SPI, MAC address filtering, IPv6 support, CBWFQ, WFQ, ACL support, QoS, DHCP server, DNS proxy, NetFlow
IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.3ah, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
24.13 cm x 22.86 cm x 4.45 cm
Europe
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.3ah, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0), CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EN 61000-4-3, EN 61000-4-6, AS/NZS 3548, FCC CFR47 Part 15, VCCI V-3
RAM
256 MB (installed) / 256 MB (max)
Flash Memory
128 MB (installed) / 128 MB (max)
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex B, ITU G.992.3 Annex B
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
2 dBi
External power adapter - 30 Watt
Europe
OS Provided
Cisco IOS Advanced Security
24.13 cm
22.86 cm
4.45 cm
10 - 85%
Type: Wireless router
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11n (draft 2.0)
Brand: Cisco
