Cisco Catalyst Compact 3560C-12PC-S Switch
Quicklinx: 91XXWS00 Mfr#: WS-C3560C-12PC-S
The Cisco Catalyst 3560-C series compact switch is a small form-factor Gigabit Ethernet and Fast Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
  • Robust security
    Equipped with Kerberos, RADIUS, Secure Shell (SSH), and TACACS+ authentication methods, this switch ensures secure network access and management, safeguarding against unauthorized access and threats.
  • Comprehensive networking capability
    Supports a wide range of IEEE standards including 802.1D/Q/ab/ae and more, alongside features like VLAN support, Quality of Service (QoS), and IPv6 support, making it versatile for various networking needs.
  • Efficient power management
    With Power over Ethernet (PoE) support on 12 ports, this device facilitates centralized power management for PoE devices, reducing cable clutter and power infrastructure complexity.
  • Advanced control and monitoring
    Features such as Access Control List (ACL) support, Dynamic ARP Inspection (DAI), and Remote Switch Port Analyzer (RSPAN) offer advanced control and monitoring of network traffic, enhancing security and performance.
  • High performance
    Delivers forwarding performance of 10 Gbps, ensuring efficient data handling and transfer across the network, suitable for high-demand environments.
Cisco Catalyst Compact 3560C-12PC-S - switch - 12 ports - Managed
Switch - 12 ports - Managed
Subtype
Fast Ethernet
Ports
12 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9018 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, OSPFv2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DAI, UDLD, fanless, RSPAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at
26.9 cm x 23.8 cm x 4.4 cm
1.9 kg
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
12 x 10Base-T/100Base-TX - RJ-45 PoE , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x RS-232 - RJ-45 management , 2 x SFP (mini-GBIC)
Internal power supply
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS IP Base
26.9 cm
23.8 cm
4.4 cm
1.9 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
91XX C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
91XX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.65
