Cisco Catalyst 2960 Series Intelligent Ethernet Switches are a new family of fixed-configuration standalone devices that provide desktop Fast Ethernet and Gigabit Ethernet connectivity, enabling enhanced LAN services for entry-level enterprise, mid-market, and branch office networks. The Catalyst 2960 Series offers integrated security, including network admission control (NAC), advanced quality of service (QoS), and resiliency to deliver intelligent services for the network edge.
- Cisco Catalyst 2960-48TC - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 48 x 10/100 + 2 x combo Gigabit SFP
- Performance
- Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 10.1 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
- Layer 2 switching, auto-sensing per device, dynamic IP address assignment, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, LACP, Port Security, MAC Address Notification, RSPAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44.5 cm x 33.1 cm x 4.4 cm
- 3.63 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- Performance
- 8K entries
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 64 MB
- Flash Memory
- 32 MB Flash
- Status Indicators
- Port transmission speed, port duplex mode, power, link OK, system, link/activity
- 2 x 1000Base-T RJ-45 , 48 x 100Base-TX RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 39 Watt
- Rack Mounting Kit
- Optional
- MTBF
- 336,409 hours
- TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, VCCI Class A ITE, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
- Software Included
- Cisco LAN Base software
- 44.5 cm
- 33.1 cm
- 4.4 cm
- 3.63 kg
- Limited warranty - lifetime
- -5 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco 100FX SPF GE SFP Port for DSBU | In Stock | £163.36 |
Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £117.91 |
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £40.21 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £83.07 |
Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £78.60 |
