Cisco Business 350 Series 350-8P-2G - Switch - L3 - Managed
Quicklinx: G18JWS00 Mfr#: CBS350-8P-2G-UK
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
£272.22 ex VAT
£326.66 inc VAT
Cisco Business 350 series switches are affordable managed switches that provide critical building blocks for any small office network. Intuitive dashboard simplifies network setup, and advanced features accelerate digital transformation, while pervasive security protects business-critical transactions. Cisco Business 350 series switches provide the ideal combination of affordability and capabilities for small office and help you create a more efficient, better-connected workforce.
Cisco Business 350 series switches are fixed-configuration managed Ethernet switches. All Cisco Business 350 series switches support the advanced security management capabilities and network features you need to support enterprise-class data, voice, security, and wireless technologies. At the same time, these switches are simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
  • SWITCH PORTS
    8-Port 10/100/1000 + 2 x 1GE copper/SFP combo
  • SIMPLE
    Intuitive Cisco Business Dashboard or on-box U/I simplifies network operations and automates lifecycle management
  • POWER-OVER-ETHERNET
    8 PoE ports with 67W total power budget, PoE, PoE+
  • ENHANCED SECURITY
    IP-MAC port biding detects and blocks deliberate network attacks. IPv6 First Hop Security provides unparalleled protection against a vast range of address spoofing and man-in-the-middle attacks on IPv6 networks
  • INNOVATIVE DESIGN
    Elegant and compact design, ideal for installation outside of wiring closet such as retail stores, open plan offices, and classrooms
Cisco Business 350 Series 350-8P-2G - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
67 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
RPVST+ instances: 126 , MSTP instances: 8 , VLANs supported: 4094 , ACL rules: 1024 , Buffer capacity (MB): 1.5
MAC Address Table Size
16K entries
Jumbo Frame Support
2KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MLDv2, MLD, CIDR, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, SCP, ICMP, DHCP, RSTP, TACACS+, RADIUS
Flow control, BOOTP support, ARP support, VLAN support, Syslog support, DoS attack prevention, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, firmware upgradable, SNTP support, DHCP snooping, QoS, DHCP server, DAI, PVST+, reset button, STP Root Guard, UDLD, fanless, LACP support, LLDP support, DHCP relay, MIB, MVR, GVRP, 802.1x authentication, ToS, DSCP support, cable test, IP source guard, SmartPort technology, dual image support, DNS client, SCT, PVE, LLDP-MED, IPMB, SSD, ISATAP tunnel support, RA guard, UDP, WRR, HOL Blocking Prevention, loopback detection, Unknown Storm Control, BPDU Guard, LAG, VSDP, RPVST+, DAD
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3at, IEEE 802.3az
26.8 cm x 32.3 cm x 4.4 cm
3.5 kg
Kuwait, Qatar, Saudi Arabia, Hong Kong, Malaysia, Singapore, United Kingdom
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
67 W
Performance
16K entries
Jumbo Frame Support
2KB
Max Units In A Stack
4
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2)
X ARM: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Status, PoE, link/activity/speed
8 x 10/100/1000 Base-T RJ-45 PoE+ , 2 x 1000Base-T / 1000Base-X RJ-45/SFP , 1 x console (mini-USB) Type B , 1 x USB Type A , 1 x console RJ-45
Internal power supply
83.17 Watt
Rack Mounting Kit
Included
MTBF
1,786,412 hours
UL 60950, CSA 22.2, FCC CFR47 Part 15 B Class A, USGv6
26.8 cm
32.3 cm
4.4 cm
3.5 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
-5 °C
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: Yes
POE: PoE+
Brand: Cisco
