Cisco ATA 190 VoIP Phone Adapter
Quicklinx: C1HJWS00 Mfr#: ATA190
The Cisco ATA 190 analog telephone adaptor is a handset-to-Ethernet adaptor that turns traditional telephone devices into IP devices. Customers can take advantage of the exciting IP telephony applications by connecting their analog devices to Cisco ATAs.
  • Protects existing telephone investment
    The Cisco ATA 190 supports two voice ports (RJ-11 phone ports), each with its own independent telephone number, and a single RJ-45 10/100 BASE-T Ethernet port. Each port supports either voice calls or fax sessions, and both ports can be used simultaneously. This adaptor can use existing Ethernet LAN deployments.
  • Is cost-effective
    The Cisco ATA 190 helps customers turn their analog phone devices into IP devices cost-effectively and is the preferred solution to address the needs of customers who connect to enterprise networks, small-office environments, or the emerging VoIP managed voice services and local services market.
Cisco ATA 190 - VoIP phone adapter
VoIP phone adapter
External
Ethernet, Fast Ethernet
VoIP Protocols
SIP, SRTP
Telephony Interfaces
2 phone (FXS)
AC 120/230 V / DC 5 V
10.1 cm x 10.1 cm x 2.8 cm
153 g
90 days warranty
VoIP phone adapter
10.1 cm
10.1 cm
2.8 cm
153 g
External
Wired
Framing Format
G.711
Network / Transport Protocol
DHCP
Remote Management Protocol
TFTP
Dynamic IP address assignment, DHCP support, Trivial File Transfer Protocol (TFTP) support, Class of Service (CoS), Type of Service (ToS)
Encryption Algorithm
TLS
IEEE 802.1p
IP Telephony
VoIP Protocols
SIP, SRTP
Voice Codecs
G.729a, G.729ab, G.711u, G.711a, T.38
2 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), DTMF generation/detection
1 x 100Base-TX - RJ-45 , 2 x modem - RJ-11
UL, ICES-003, RoHS, A-Tick, FCC CFR47 Part 15 B
External power adapter
5 Watt
Limited warranty - 90 days
45 °C
0 - 90% (non-condensing)
