Delivering up to three times more coverage versus competition for tablets, smart phones and high performance laptops, the industry's only 4 x 4 MIMO, 3 spatial stream access point delivers mission critical reliability. Current solutions struggle to scale to meet demands on the wireless networks from the influx of diverse mobile devices and mobile applications. The Cisco Aironet 3600 series sustains reliable connections at higher speeds further from the access point than competing solutions, resulting in up to three times more availability of 450 Mbps rates, and optimizing the performance of more mobile devices.
RF excellence
Building on the Cisco Aironet heritage of RF excellence, the 3600 series is a flagship access point, delivering industry-leading performance for secure and reliable wireless connections. -
Scalability
The Cisco Aironet 3600 series is a component of the Cisco unified wireless network, which can scale to up to 18,000 access points with full Layer 3 mobility across central or remote locations on the enterprise campus, in branch offices, and at remote sites.
- Cisco Aironet 3602I - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 22.1 cm x 22.1 cm x 4.7 cm
- 1.04 kg
- Limited lifetime warranty
- 22.1 cm
- 22.1 cm
- 4.7 cm
- 1.04 kg
Processor / Memory / Storage
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Line Coding Format
- CCK
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Status
- Auto-sensing per device, power over Ethernet (PoE), MIMO technology, Wi-Fi Multimedia (WMM) support, CleanAir technology, Maximum Ratio Combining (MRC)
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
- Authentication Method
- MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11n
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- Mounting Kit
- Included
- VCCI, ICES-003, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - lifetime , Limited warranty - advance parts replacement - 10 days
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.92 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.60 |
