Cisco Unified Communications 500 Series for Small Business, a critical part of the Cisco Smart Business Communications System, is a unified communications solution for small businesses that provides voice, data, voicemail, Automated Attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, e-mail, and customer relationship management (CRM) programs. This easy-to-manage platform uses business-class, proven unified communications technologies to full advantage and supports flexible deployment models based on your needs - a wide array of IP phones, public switched telephone network (PSTN) interfaces, and Internet connectivity.
- Cisco Unified Communications 520 for Small Business - VoIP gateway
- VoIP gateway
- Licence Qty
- 8 users
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet
- VoIP Protocols
- H.323, SCCP, SIP
- Telephony Interfaces
- 4 phone (FXS), 4 line (FXO)
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 26.7 cm x 28 cm x 6.7 cm
- 3.6 kg
- 1-year warranty
- VoIP gateway
- Installed Modules Qty (Max)
- 0 (1)
- 26.7 cm
- 28 cm
- 6.7 cm
- 3.6 kg
- Form Factor
- External
- Connectivity Technology
- Wired
- Switching Protocol
- Ethernet
- Remote Management Protocol
- SNMP
- Firewall protection, MAC address filtering
- Encryption Algorithm
- LEAP, PEAP, TKIP, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
- IEEE 802.3af, IEEE 802.1x
IP Telephony
- VoIP Protocols
- H.323, SCCP, SIP
- Voice Codecs
- G.711, G.729a
- IP Telephony Features
- Call waiting, call hold, call transfer
- Expansion Slots
- 1 (total) / 1 (free) x VIC
- 4 x modem - RJ-11 , 4 x modem - RJ-11 , 8 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x 100Base-TX - RJ-45 , 1 x audio , 1 x management
- CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, CSA 22.2 No. 60950, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 386
- PoE
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85%
