Cisco 881 Ethernet Security Router - 4-port switch
Quicklinx: 7QN3WS00 Mfr#: CISCO881-SEC-K9
The Cisco 880 series integrated services routers combine Internet access, security and wireless services onto a single, secure device that is simple to use and manage for small businesses and enterprise small branch and teleworkers. The Cisco 880 series delivers features, including firewall, content filtering, VPNs, and WLANs, at broadband speeds to small offices. Easy deployment and centralized management features enable the Cisco 880 series to be deployed by enterprises or service providers in small branch offices or small businesses.
Cisco 881 Ethernet Security - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
L2TP, IPSec
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, GRE
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH
NAT support, ISP, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, SPI, content filtering, MAC address filtering, IPv6 support, Stateful Failover, CBWFQ, WFQ, ACL support, QoS, DMVPN, DHCP server, VRF-Lite, DNS proxy
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
32.5 cm x 24.9 cm x 4.4 cm
Enclosure Type
Desktop
Wired
L2TP, IPSec
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
RAM
256 MB (installed) / 768 MB (max) - DDR2 SDRAM - SO-DIMM 200-pin
Flash Memory
128 MB
Status Indicators
Port status, power
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
Expansion Slots
1 (total) / 1 (free) x SO-DIMM 200-pin
External power adapter - 60 watt
OS Provided
Cisco IOS Advanced IP services
32.5 cm
24.9 cm
4.4 cm
10 - 85%
