Cisco 3900 series Integrated Services Routers provide rich media collaboration and virtualization to the branch while maximizing operational cost savings. The Integrated Services Routers are future-enabled with support for high capacity DSPs (Digital Signal Processors) for future enhanced video capabilities, high powered service modules with improved availability, multi-core CPUs, Gigabit Ethernet switching with enhanced POE.
Services integration
The Cisco 3900 series routers offer increased levels of services integration with voice, video, security, mobility, and data services. The Cisco 3900 series provides the highest performance and slot densities among the routers in the Cisco ISR G2 portfolio, enabling you to maximize services integration and reducing overall capital and operational costs. -
Services on demand
The Universal image contains all of the Cisco IOS technology sets which can be activated with a software license. This allows your business to quickly deploy advanced features without downloading a IOS image. The Cisco Services Ready Engine (SRE) enables an operational model which allows you to reduce capital expenditures (CapEx) and deploy a variety of application services as needed on a single integrated compute services module. -
Network agility
Designed to address customer business requirements, the Cisco 3900 series with the modular architecture offers increased capacity and performance as your network needs grow. The Services Performance Engine (SPE) modular motherboard enables upgrades to processing capability in the future. Dual integrated power supplies provide power redundancy or can be configured to provided additional ePOE power to endpoints. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency. -
Energy efficiency
The Cisco 3900 series offers intelligent power management and allows the customer to control power to the modules based on the time of day. Cisco EnergyWise technology will be supported in the future. Services integration and modularity on a single platform performing multiple functions, optimizing raw materials consumption and energy usage. Platform flexibility and ongoing development of both hardware and software capabilities lead to a longer product lifecycle, lowering all aspects of the total cost of ownership, including materials and energy use. High efficiency power supplies and scalable power consumption based on your network needs. -
Investment protection
The Cisco 3900 series maximizes investment protection. Reuse of a broad array of existing modules supported on the original Integrated Services Routers provides a lower cost of ownership. A rich set of Cisco IOS Software features carried forward from the original integrated services routers and delivered in a single universal image.
- Cisco 3925 - router - desktop
- Router
- Enclosure Type
- Desktop - modular - 3U
- Data Link Protocol
- Capacity
- Cisco Unified Communications Manager Express sessions: 250 , Cisco Unified SRST sessions: 730
- IPSec, PPPoE, L2TPv3
- Routing Protocol
- OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP, RMON
- MPLS support, Syslog support, IPv6 support, CBWFQ, WRED, QoS
- IEEE 802.3, IEEE 802.1Q, IEEE 802.1ah, IEEE 802.1ag
- Power
- AC 120/230 V (47/63 Hz)
- 47.6 cm x 43.8 cm x 13.3 cm
- 17.7 kg
- 90 days warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- SNMP, RMON
- Encryption Algorithm
- SSL
- IEEE 802.3, IEEE 802.1Q, IEEE 802.1ah, IEEE 802.1ag, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, AS/NZ 3548 Class A, CAN/CSA-E60065-00, ICES-003 Class A, CS-03, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60065, BSMI CNS 13438, EN 300 386
- RAM
- 1 GB (installed) / 2 GB (max)
- Flash Memory
- 256 MB (installed) / 8 GB (max)
- Status Indicators
- Power, link/activity
- 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , 2 x SFP (mini-GBIC)
- Expansion Slots
- 4 (total) / 4 (free) x EHWIC , 4 (total) / 4 (free) x PVDM , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x expansion slot , 2 (total) / 2 (free) x service module (SM)
- Power Device
- Internal power supply
- Voltage Required
- OS Provided
- Cisco IOS IP Base
- 47.6 cm
- 43.8 cm
- 13.3 cm
- 17.7 kg
- Limited warranty - 90 days
- 0 °C
- 40 °C
- 5 - 85%
