Cisco 300Mbps Wless-N Access Point
Quicklinx: 5L96WS00 Mfr#: WAP4410N-G5
  • IEEE 802.11n (draft)
With the growth of high-bandwidth applications, such as storage and video, in the workplace, network performance is essential. Wireless technology is no longer lagging behind wired performance. The Cisco WAP4410N Wireless-N Access Point answers the growing business need for access, speed, and security. Power over Ethernet (PoE) support makes the access point easy to install - you can mount it anywhere, even without ready access to a power plug. With appropriate PoE support at the other end, you need to run only one cable to the access point to deliver both data and power. Of course, you can also use the included AC adapter if power is available nearby.
Moreover, the integrated quality of service (QoS) features provide consistent voice and video quality on both the wired and wireless networks, enabling the deployment of business-quality voice over IP (VoIP) and video applications. To protect your data and privacy, the Cisco Wireless-N Access Point supports the industrial strength wireless security of Wi-Fi Protected Access (WPA), encoding all your wireless transmissions with powerful encryption. The MAC address filter lets you decide exactly who has access to your wireless network, and advanced logging keeps you apprised of access attempts. The rogue access point detection capability notifies the administrator when an unauthorized access point is detected in the airspace. The WPS (Wi-Fi Protected Setup) feature facilitates simple and secure deployment of security in the wireless network. Configuration is a snap with the web browser-based configuration utility. The Cisco WAP4410N Wireless-N Access Point is the best way to add wireless access to your existing business network.
Cisco Small Business WAP4410N - radio access point - Wi-Fi
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
17 cm x 4.1 cm x 17 cm
390 g
Radio access point
17 cm
4.1 cm
17 cm
390 g
External
Wireless
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz
Status Indicators
Power, link OK, link/activity
Power over Ethernet (PoE), load balancing, VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), DHCP client
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft), Wi-Fi Protected Setup
Aerial
Antenna
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
2 dBi
1 x 1000Base-T - RJ-45
1 x network cable
IC, FCC
PoE
External power adapter
OS Provided
Linux
10 - 85%
