Cisco 3 LINE IP PHONE WITH DISPLAY
Quicklinx: 788WWS00 Mfr#: SPA303-G3
Based on SIP, the Cisco SPA303 3-line IP phone with 2-port switch helps ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA303 addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances are just some of the many advantages of the SPA303.
The Cisco SPA303 uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
  • Comprehensive interoperability and SIP-based feature set
    Based on SIP, the Cisco SPA 303 3-line IP phone with 2-port switch helps ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA 303 addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances are just some of the many advantages of the SPA 303.
  • Carrier-grade security, provisioning, and management
    The Cisco SPA 303 uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
Cisco Small Business SPA 303 - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
G.722, G.729ab, G.711u, G.711a, G.726
Lines Supported
Multiline
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Automatic Redial
Speed Dial Capacity
8
Missed Calls Memory
60
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
United Kingdom
1-year warranty
VoIP phone
United Kingdom
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Automatic Redial
Menu Operation
Function Buttons
Voice mail button, speakerphone button, headset button, mute button, hold button
Volume Control
Ringer Control
Ring Tones
10
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer, built-in clock, Pager Call, automatic redial
Additional Features
On-hook dialling, music on hold, built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP, static
Security
256 bit AES
Network Protocols
IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
Network Ports Qty
Voice Features
Voice activity detection (VAD)
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
100 names & numbers
Missed Calls Memory
60
Dialed Calls Memory
60
Call Log Capacity
60 numbers
Speed Dial Capacity
8
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Headset jack / sub-mini-phone 2.5mm
Network cable
Stand, power adapter
UL, FCC Part 15 B, A-Tick
Power adapter - external
Dimensions & Weight (Base)
22 cm
3 cm
19.8 cm
0.7 kg
Limited warranty - 1 year
