Stylish and functional in design, the Cisco SPA942 4-line IP Phone with 2-port Switch is ideal for a residence or business using a hosted IP telephony service, an IP private branch exchange (PBX), or a large-scale IP Centrex deployment. The Cisco SPA942 uses industry-leading voice over IP (VoIP) technology from Cisco to deliver an upgradeable high-quality IP phone that is unparalleled in features, value, and support.
Based on the Session Initiation Protocol (SIP), the Cisco SPA942 has been tested to ensure comprehensive interoperability with equipment from VoIP infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers.
With hundreds of features and configurable service parameters, the Cisco SPA942 addresses the requirements of traditional business users while taking advantage of the benefits of IP telephony. Features such as easy station moves, presence, and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages.
Standard features on the Cisco SPA942 include two active lines, dual-switched Ethernet ports, 802.3af Power over Ethernet (PoE) support, a high resolution graphical display, full duplex speakerphone, and a 2.5mm headset port. With a simple software update, the SPA942 is upgradeable to a 4-line phone. Each line can be independently configured to use a unique phone number (or extension), or can use a shared number that is assigned to multiple phones.
- Cisco Small Business Pro SPA942 4-line IP Phone with 2-port Switch - VoIP phone
- Product Type
- VoIP phone
- VoIP Protocols
- SIP v2
- Voice Codecs
- G.711, G.723.1, G.729a
- Speakerphone
- Caller ID
- Voice Mail Capability
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Automatic Redial
- Display
- LCD display - monochrome
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Product Type
- VoIP phone
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Automatic Redial
- Function Buttons
- Speakerphone button, headset button, flash button, auto redial button
- Volume Control
- Ringer Control
- Indicators
- Voice message waiting indicator
- Additional Functions
- Call timer, automatic redial
- Additional Features
- On-hook dialling, music on hold, built-in web server
IP Telephony
- VoIP
- VoIP Protocols
- SIP v2
- Voice Codecs
- Quality of Service
- IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.3
- IP Address Assignment
- DHCP
- Power Over Ethernet (PoE) Support
- Network Protocols
- TCP, UDP, ICMP, ARP, DNS, SNMP
- Network Ports Qty
- Voice Features
- Voice activity detection (VAD)
- Network Features
- Network Address Translation (NAT)
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- Call Log Capacity
- 60 numbers
Display
- Display Resolution
- 128 x 64 pixels
- Connections
- Headset jack / sub-mini-phone 2.5mm
- Cables Included
- Network cable - 1.8 m , Handset cord - 56 cm
- Included Accessories
- Power adapter
- ICES-003, FCC Part 15
- Power adapter - external
Dimensions & Weight (Base)
- 19.5 cm
- 18 cm
- 16 cm
- 1 kg
