Cisco MFE and MGE Small Form-Factor Pluggable (SFP) transceivers are easy-to-install modules that provide a simple way to add fiber connectivity or to add an extra Gigabit Ethernet port to your Cisco small business or Cisco small business pro series switches. The Cisco MFE and MGE transceivers provide fast and reliable connectivity between switches that are located on different floors, in separate buildings, or on a small campus network needing connectivity between sites. These transceivers can support both Fast and Gigabit Ethernet applications.
Easy to use
The Cisco Small Business Gigabit Power over Ethernet injector is easy to use; simply connect the injector to the PoE endpoint and to an Ethernet switch to provide midspan power. -
Supports wireless LAN deployments
The Cisco Small Business High Power Gigabit Power over Ethernet injector works with wireless access points to provide wireless LAN connectivity for small to medium-sized businesses. -
Enables network expansion
Add PoE capabilities to non-PoE Ethernet switches to provide combined power and data over a single Cat 5e or better connection. -
Offers investment protection
Protect the investment of your existing Ethernet equipment and cabling infrastructure by using this high-power remote PoE solution.
- Cisco Small Business MFEBX1 - SFP (mini-GBIC) transceiver module - 100Mb LAN
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-BX20-U
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 20 km
- 0.9 cm x 5.6 cm x 1.3 cm
- 18 g
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-BX20-U
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 20 km
- 1 x Ethernet 100Base-BX20-U - LC single-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, FCC Part 15 B, EN 60825, IEC 60825-1, FDA
- 0.9 cm
- 5.6 cm
- 1.3 cm
- 18 g
- 0 °C
- 70 °C
- 10 - 85%
