Cisco Rugged SFP (mini-GBIC) Transceiver Module - Gigabit Ethernet
Quicklinx: C634WS00 Mfr#: GLC-LX-SM-RGD=
Type: [N/A]
44 In Stock
£680.11 ex VAT
£816.13 inc VAT
The industry-standard Cisco Small Form-Factor Pluggable (SFP) transceiver modules are hot-swappable input/output (I/O) devices that plug into 100BASE, 1000BASE and 10GBASE ports (for SFP+), which connect the module port with the fiber-optic or copper network.
The 1000BASE-LX/LH SFP transceiver module for SMF, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard singlemode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers. When used over legacy multimode fiber type, the transmitter should be coupled through a mode conditioning patch cable.
Cisco Rugged SFP - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
1-year warranty
Cisco 3270, 3270 Rugged Integrated Services Router Card; Catalyst ESS9300 Embedded Series
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1 x Ethernet 1000Base-LX - LC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
Limited warranty - 1 year
-40 °C
85 °C
Cisco 3270, 3270 Rugged Integrated Services Router Card , Cisco Catalyst ESS9300 Embedded Series
Type: [N/A]
Brand: Cisco
Price Range Ex VAT: £500 - £750
