Productive easy-to-use mono laser All-in-One. Network ready and packed with features to boost productivity this energy efficient mono laser All-In-One can be shared seamlessly around the office, plus it's easy-to-use with tilt and touch control.
Productive, networked All-in-One for small offices
This stylish, high-speed All - In-One mono laser printer offers print, copy, scan and fax functions in one compact space saving device. With Ethernet connectivity for easy network sharing of functions, plus professional print quality and easy touch screen operation, it's the ideal desktop solution for small offices. -
Fast printing and copying
There's no waiting by the machine for documents to output, thanks to a fast A4 mono laser print and copy speed of 23ppm and a Quick First Print Out Time from sleep mode. Multi-page scanning and copying is effortless thanks to a 250-sheet paper cassette and an integrated 35-sheet ADF. -
Business quality results
A combination of print quality and Canon's EF toner delivers professional prints and copies with sharp crisp text and smooth graphics. Enhanced color scanning captures every detail from originals. Send scans to any PC with user-friendly network scanning. -
Quick, simple touch operation
Quick and simple to operate, the i-SENSYS MF216n has a versatile, tilting display panel with a large touch screen LCD, which shows you the information you need at a glance. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys, so it's easy to send scans to file or save paper by copying several images to one sheet. -
Energy efficient
Canon's On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes just 1.6 Watts in sleep mode. -
Quiet mode
This multifunctional is silent in standby mode, while for operation in a quiet environment, Quiet Mode ensures less noisy printing - so you can work without distracting others. -
All-in-One cartridge
The recyclable All-in-One cartridge ensures maintenance-free operation and reliable high quality output. The Authentic Canon Laser Cartridge contains toner, drum and cleaning units and can be replaced in seconds without any fuss or mess.
- Canon i-SENSYS MF216n - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Max Copying Speed
- Up to 23 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 23 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- Power
- AC 230 V (50/60Hz)
- 39 cm x 44.1 cm x 36 cm
- 11.5 kg
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 pages
- Display
- 6 lines
- Display Features
- Touch screen
- Interface
- USB 2.0, LAN
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 23 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 23 ppm
- Printer Drivers / Emulations
- UFRII LT
- Image Enhancement Technology
- Automatic Image Refinement
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 256 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 4 station(s)
- Speed Dialing
- 104 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 114 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
- Min Original Size
- 105 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 100 sheets
- Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 1270 Watt
- Power Consumption Standby
- 5.4 Watt
- Power Consumption Sleep
- 1.6 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1700 pages
- 39 cm
- 44.1 cm
- 36 cm
- 11.5 kg
- Sound Emission
- 43 dB (idle) / 50 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
