Canon i-SENSYS LBP251dw Printer Monochrome Duplex Laser
Quicklinx: C05DWS00 Mfr#: 0281C022
Compact A4 B&W laser printer that's ideal for small businesses and workgroups. This A4 B&W laser printer is fast, straightforward and reliable. With a great choice of cloud and mobile device options, it's perfect for high quality printing for workgroups and small businesses.
  • The ideal first step into business quality print
    Looking to make your first step up to a business quality printer, because you want faster, higher quality and more reliable print? Then look no further than the i-SENSYS LBP251dw A4 B&W laser printer. Small businesses and workgroup teams can complete everyday tasks faster with rapid 30 ppm output and the ability to start printing from idle or standby in just a few seconds. And with compact size and smart looks, it's ideal in customer-facing or space-constrained environments.
  • Sustained quality, easy ownership
    Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon's easy-to-replace All-in-One cartridge design. Choose the longer-lasting high yield cartridges if you prefer your printer to run longer with fewer interventions. And reduce your admin burden with just a single cartridge to keep track of, which means fewer items to order and manage.
  • Powerful support for mobile and cloud
    If you and your teams enjoy the flexibility of moving seamlessly between locations and devices, the LBP251dw is your ideal printer. No matter how or where you choose to work, your LBP251dw is always ready and accessible. Print from your iPhone or iPad via Apple AirPrint, or your Android device using Google Cloud Print, regardless of whether you're inside or outside the office.
  • Network and integration-ready
    The LBP251dw offers sophisticated capabilities for integrating seamlessly with IT networks. Support for PCL5e/6 makes it an ideal choice for managed environments; while the Remote User Interface saves valuable time because IT Managers can monitor and update settings without making a site visit. And with Wi-Fi and Ethernet connectivity as standard, the LBP251dw has all the features you need to keep pace with your growing business.
Canon i-SENSYS LBP251dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
12.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 16 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
525 MHz
Language Simulation
PCL 5E, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, labels, plain paper, index cards, heavy-weight paper, recycled paper, postcards
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 2500 pages
Print server
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
40 cm x 37.7 cm x 29.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6 sec
Language Simulation
Media Handling
525 MHz
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 2500 pages
Print server
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 719
ISO/IEC 19752, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
1150 Watt
Power Consumption Stand by
12.1 Watt
Power Consumption Sleep
1 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
53 dB
40 cm
37.7 cm
29.8 cm
12.4 kg
C05D C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
