Canon A3 and Colour Photo Wireless Printer 4800 x 1200 dpi 1 Year
Quicklinx: G9L1WS00 Mfr#: 4280C008
Focused on vibrant color photo printing, versatility, and usability, the Canon PIXMA PRO-200 is the ideal choice for photo enthusiasts and aspiring photographers.
  • Impressive high-quality photographs
    With a superior 8-color dye-based ink system, you're guaranteed exceptional reproduction, richer colors, and vibrant professional printing, every time.
  • Pick paper that suits you
    With versatile media handling and customisable printing sizes, you can enhance your photographs on a variety of paper including fine art, borderless and panoramic.
  • Quick and easy to use
    The built-in 3-inch LCD display lets you check ink levels, perform printer maintenance, and access printer instructions at a glance - for excellent results with ease.
  • Perfect printing every time
    With 3 paper feed options and auto paper skew correction function, you can bid farewell to misalignment and printing fails, no matter what paper you're using.
  • One seamless process
    Canon's user-friendly PPL (Professional Print & Layout) software means you can shoot and send photos with ease from popular photography programs for a one-stop edit-to-print experience.
  • Compact and lightweight
    Even with A3+ paper capabilities, Canon PIXMA PRO-200 remains a lightweight solution for your printing needs. And it's compact too, so fits easily into a small studio.
  • For faster, more efficient printing
    Great shots happen in a flash, and so does great printing. Canon PIXMA PRO-200 is fast and efficient, delivering exceptional quality A3+ printouts in just 90 seconds, giving you more time to find the next great shot.
Canon PIXMA PRO-200 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
14.1 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
8-ink
Max Media Size
A3 Plus (329 x 483 mm)
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
329 mm x 990.6 mm
Print Speed
Up to 1.5 min/page - photo - A3 plus (329 x 423 mm)
Max Resolution (Colour)
4800 x 2400 dpi
LAN, Wi-Fi(n), USB 2.0
AirPrint Enabled
Preview Screen Size
3"
Media Type
Plain paper, photo paper, fine art paper, DVD discs, CD discs, BD discs, envelopes, iron-on transfers, nail stickers
Total Media Capacity
100 sheets
Media Handling
100-sheet input tray, CD/DVD tray, 1-sheet manual tray
Print server
Printer Features
Borderless printing
Windows 10 Mobile
63.9 cm x 37.9 cm x 20 cm
Printer Type
Printer
Inkjet Technology
8-ink
Nozzle Configuration
6144 nozzles
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Canon ChromaLife100+
Print Speed
Built-in Devices
LCD display
Preview Screen Size
3"
Wireless
AirPrint Enabled
4800 x 2400 dpi
Direct Printing Specifications
PictBridge
Printer Features
Borderless printing
Media Handling
Media Handling
Media Type
Max Media Size
89 mm x 127 mm
329 mm x 990.6 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A3 Plus (329 x 483 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 148 mm, 177.8 x 254 mm, 304.8 x 304.8 mm, 88.9 x 127 mm, CD (120 mm), 101.6 x 152.4 mm, 127 x 177.8 mm, 203.2 x 254 mm, 254 x 304.8 mm, 127 x 127 mm, Panoramic A2 (210 x 594 mm), 329 x 990.6 mm
Borderless Photo Sizes
A3 Plus (329 x 483 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A5 (148 x 210 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 100 x 148 mm, 177.8 x 254 mm, 304.8 x 304.8 mm, 203.2 x 254 mm, 127 x 177.8 mm, 88.9 x 127 mm, 101.6 x 152.4 mm, 254 x 304.8 mm, 127 x 127 mm, Panoramic A2 (210 x 594 mm)
Envelope Sizes
Com-10 (105 x 241 mm), International DL (110 x 220 mm)
Media Weight
64 g/m² - 380 g/m²
100 sheets
Media Feeders
Input tray: 1 x automatic - 100 sheets - A3 Plus (329 x 483 mm) weight: 64 g/m² - 380 g/m² , 1 x manual - 1 sheet - A3 Plus (329 x 483 mm) 380 g/m² , 1 x automatic - CD (120 mm)
Print server
Remote Management Protocol
SNMP, HTTP, IPv4, IPv6
Security Protocols & Features
802.1x, WEP, EAP-TLS, EAP-TTLS, PEAP, WPA-PSK, TKIP, AES, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
8 x ink tank
PIXMA Cloud Link
Power supply
Frequency Required
50/60 Hz
1.6 watt
Power Consumption Stand by
1 watt
Software Included
Drivers & Utilities
Windows 10 Mobile
Sound Emission (Operating)
42.5 dB
63.9 cm
37.9 cm
20 cm
14.1 kg
G9L1 Canon CLI65Y Yellow Ink Cart In Stock £12.88
G9L1 Canon CLI-65 GY - Grey - original - ink tank - for PIXMA PRO In Stock £13.91
G9L1 Canon 4216C001 CLI65C Cyan Ink Cart 13ML In Stock £12.88
G9L1 Canon 4216C001 CLI65C Magenta Ink Cart 13ML In Stock £14.00
G9L1 Canon 4222C001 LT Grey Ink Cartridge 13M In Stock £13.49
G9L1 Canon Photo Magenta Ink Tank In Stock £13.49
G9L1 Canon Photo Cyan Ink Tank In Stock £13.90
G9L1 Canon 4215C001 CLI65BK Black Ink 13ML In Stock £13.90
