Cables Direct Yellow 0.25m Network 5E 26AWG Moulded Boot
Quicklinx: CHTKWS00 Mfr#: 99TRT-600-HY
Category 5e cable is a twisted pair high signal integrity cable type often referred to as Cat5e. Most cables are unshielded, relying on the twisted pair design for noise rejection, some are shielded. Often used in computer networks such as Ethernet.
Cables Direct Economy patch cable - 25 cm - yellow
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Molded, snagless, CCA stranded cores
Length
25 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
26
Length
25 cm
Yellow
Connector
RJ-45 - male
RJ-45 - male
