StarTech.com 3m QSFP+ Breakout Cable
Quicklinx: D9TYWS00 Mfr#: QSFP4SFPPC3M
Length: 3m
Colour: Black
Select:
  • 3m
£44.85 ex VAT
£53.82 inc VAT
Connect four MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications such as point-to-point in-rack and across-rack network switch or server connections, for up to four 10G SFP+ devices.
StarTech.com MSA Uncoded Compatible 3m 40G QSFP+ to 4x SFP+ Direct Attach Breakout Cable Twinax, 40GbE QSFP+ to 4x SFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC Cable - Lifetime Warranty (QSFP4SFPPC3M) - breakout cable - 3 m - black
Breakout cable - SFF-8431/SFF-8432/SFF-8436
Twinaxial
Passive cable
Length
3 m
Connector
QSFP+ - latched
Connector (Second End)
4 x SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
3 m
130 g
Connector
QSFP+ - latched
4 x SFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 3m
Colour: Black
