This Cisco WS-G5486 compatible GBIC transceiver provides 1000Base-LX throughput up to 10km over single-mode Fibre (SMF) at a wavelength of 1310nm using a SC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
Silver -
Connector 1
SFP Male -
Connector 2
LC Female -
Warranty
Lifetime -
SFP Male
Connector 2 -
LC Female
SFP Male
- C2G - GBIC transceiver module - GigE
- GBIC transceiver module - SC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco WS-G5486
- 3.05 cm x 6.6 cm x 1.02 cm
- 27.2 g
- Limited lifetime warranty
- Designed For
- Cisco Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4418, 4500, 4912; Network Processing Engine G1, uBR7200; Node Route Processor 2SV; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LX
- GigE
- 1 Gbps
- 1310 nm
- 10 km
- 1 x Ethernet 1000Base-LX - SC single-mode female x 2
- MSA
- Cisco WS-G5486
- 3.05 cm
- 6.6 cm
- 1.02 cm
- 27.2 g
- Limited warranty - lifetime
- Designed For
- Cisco Catalyst 2912MF, 2912MF-XL, 2912MF-XL Enterprise Edition, 2924M, 2924M-XL, 2924M-XL DC, 2924M-XL Enterprise Edition, 2948G, 2948G-GE-TX Gigabit Ethernet Switch, 2948G-L3, 2950G-12, 2950G-24, 2950G-24-EI, 2950G-48, 2950G-48-EI, 2980G, 2980G-A, 3508G XL Enterprise Edition, 3512 XL Enterprise Edition, 3512G XL Enterprise Edition, 3512XL Standard Edition, 3524-PWR XL Enterprise Edition, 3524XL Enterprise Edition, 3548XL Enterprise Edition, 3550-12G, 3550-12T, 3550-24 EMI, 3550-24 PWR EMI, 3550-24 PWR SMI, 3550-24 SMI, 3550-48 EMI, 3550-48 SMI, 4418, 4500 Series Supervisor Engine V-10GE, 4912G , Cisco Network Processing Engine G1, uBR7200-NPE-G1 , Cisco Node Route Processor 2SV , Cisco Supervisor Engine 1A 2GE, 1A 2GE Plus, 1A 2GE Plus MSFC & PFC, 1A 2GE Plus PFC, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10GE
