When you need just a little more distance, this cable will extend the reach of your existing USB A/B cable. Foil and braid shielding reduce EMI/RFI interference and twisted pair construction helps reduce crosstalk for a high speed, error-free data transfer. USB 2.0 compatible. PC and Mac compatible.
Enhanced connectivity
The 1m USB 2.0 A Male to A Female Extension Cable extends the reach of your USB devices, making it easier to connect printers, scanners, keyboards, and other peripherals to your computer without compromising on signal quality. -
Robust protection
Equipped with EMI/RFI protection, this cable ensures that your device connections are not only extended but also protected against electromagnetic and radio frequency interference, maintaining signal integrity and reliability. -
Durable design
Featuring a shielding material of foil with braid, the cable offers superior durability and minimizes signal loss, ensuring a stable and secure connection for all your devices.
- C2G 1m USB 2.0 A Male to A Female Extention Cable (3.3ft) - USB extension cable - USB to USB - 1 m
- Technology
- Shielded twisted pair (STP)
- EMI/RFI protection
- Cable Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Black
- Limited lifetime warranty
- Technology
- Shielding Material
- Foil with braid
- Cable Length
- 1 m
- Black
- 100 g
- Connector
