C2G USB C to DisplayPort Adapter Converter 4K - Black
Quicklinx: C17QWS00 Mfr#: 80521
Colours:
£25.44 ex VAT
£30.52 inc VAT
Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Converter which allows you to connect the USB Type-C port of a laptop, Chromebook, tablet or other source device to the DisplayPort input of a monitor, projector or HDTV - making it an ideal solution for showing presentations, pictures or other audio/video content. This adapter supports up to a 4K (3840x2160 at 30Hz) resolution, allowing it to deliver high-quality, ULTRA HD video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. The USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. Pairing this device with the USB-C to VGA adapter or the USB-C to HDMI adapter provides you with a video port for any situation whilst presenting.
  • Seamless compatibility
    Designed to bridge the gap between your USB-C equipped device and DisplayPort monitors or projectors, the C2G USB C to DisplayPort Adapter Converter ensures a seamless connection. This adapter supports PC compatibility, making it a versatile addition to your tech toolkit.
  • High-definition visuals
    Experience vivid, high-resolution visuals with support for 3840 x 2160 max external resolution. Whether you're presenting, streaming, or gaming, the adapter delivers clear, quality images without lag, thanks to a 30 Hz V-Sync rate at max resolution.
  • Plug-and-Play convenience
    Forget about complicated setups. This adapter is compliant with Plug-and-Play standards, allowing for a hassle-free connection without the need for additional drivers or software. Simply connect, and you're ready to go.
C2G USB C to DisplayPort Adapter Converter - USB Type C to DisplayPort Black - external video adapter - black
External video adapter
Bus Type
USB 3.1
Graphics Engine
- up to
Max Resolution
3840 x 2160
Interfaces Details
DisplayPort , USB 3.1 (USB-C)
Enclosure Colour
3-year warranty
Bus Type
USB 3.1
Max Resolution
3840 x 2160 at 30 Hz
Interfaces Details
HDCP
Plug and Play
33 g
Enclosure Colour
Limited warranty - 3 years
50 °C
Brand: C2G
