C2G USB-C to DisplayPort Adapter Converter - 4K 60Hz - Black
Quicklinx: HKZPWS00 Mfr#: C2G26933
£21.81 ex VAT
£26.17 inc VAT
This USB-C to DisplayPort Adapter Converter is ideal for showing presentations, pictures, or other audio/video content from the USB-C port of a laptop or tablet to the DisplayPort input of a monitor, projector, or HDTV. This adapter supports up to a 4K (3840 x 2160) at 60Hz resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it perfect for BYOD (Bring Your Own Device) applications in education or corporate environments. This adapter is an ideal accessory for Apple and other leading laptops and tablets.
Features and Benefits
Supports resolutions up to 4K (3840 x 2160) at 60Hz
Compatible with USB-C, Thunderbolt 3 and Thunderbolt 4 ports
A reversible, symmetrical USB-C connector
Compact, lightweight design
Plug and Play-no driver required
Compatible with the Apple MacBook , MacBook Air , and MacBook Pro.
  • High-resolution support
    Experience stunning visual clarity with the USB-C to DisplayPort Adapter Converter, supporting up to 3840 x 2160 resolution at a smooth 60 Hz refresh rate. This feature ensures your display output is vibrant and fluid, perfect for high-definition video streaming, gaming, or professional graphic design work.
  • Robust build quality
    Constructed with a nickel-plated shell and a PVC jacket, the adapter boasts durability and a minimum bend radius of 40mm, ensuring it can withstand the rigors of daily use while maintaining signal integrity. The chipset VL100 further enhances performance, making it a reliable choice for connecting your devices.
  • Universal compatibility
    Designed to be compatible with Thunderbolt 3 and Thunderbolt 4 standards, this adapter offers a seamless connection between your USB-C equipped device and DisplayPort monitors. Whether for work or play, the Plug-and-Play functionality ensures a hassle-free setup without the need for additional drivers or software.
C2G USB-C to DisplayPort Adapter Converter - 4K 60Hz - Black - video adapter - 24 pin USB-C to DisplayPort
Video adapter
4K60Hz support, nickel plated shell, Chipset VL100, minimum bend radius 40mm
Connector
24 pin USB-C - male
Connector (Second End)
20 pin DisplayPort - female
Thunderbolt 3 / Thunderbolt 4
Video adapter
Jacket Material
PVC
Outside Diameter
4 mm
Connector
24 pin USB-C - male
Thunderbolt 3 / Thunderbolt 4, Plug and Play, RoHS, REACH, VW-1, TSCA, NDAA Section 889
Brand: C2G
