The USB-C to Ethernet Adapter with 3-Port Hub is an ideal solution for wired network connectivity and data transfer on the go, in the office, or any work space. This adapter connects to a USB-C or Thunderbolt 3 enabled laptop, tablet, or desktop computer and features an Ethernet port and three USB 3.0 ports. The small form factor of this adapter makes it a portable and convenient solution that provides a Gigabit Ethernet port for a wired internet connection and three USB 3.0 ports to connect peripheral devices. The adapter is perfect for connecting to networks where Wi-Fi is unavailable or for computers that do not provide a wired Ethernet port or possibly have a damaged Ethernet port. The Ethernet port allows for reliable internet connectivity and file transfer speeds up to 1000Mbps, whilst the three USB 3.0 ports enable transfer speeds up to 5Gbps.
Efficient connectivity
The C2G USB C Ethernet and 3 Port USB Hub White offers a seamless connection to Ethernet networks with a data transfer rate of 1 Gbps, ensuring fast and reliable Internet access for all your needs. -
Enhanced expansion
With a built-in 3-port SuperSpeed USB 3.0 hub, this device expands your computer's connectivity, allowing for additional peripherals to be connected with ease. -
Plug-and-Play convenience
Designed for simplicity, this hub adheres to Plug-and-Play standards, making it straightforward to use without the need for additional drivers or software installations. -
Durable and compliant
The hub is built to last, featuring an integrated USB-C cable and compliance with RoHS standards, ensuring both durability and environmental responsibility.
 - C2G USB C Ethernet and 3 Port USB Hub White - Hub - 3 Ports - network adapter - USB-C - Gigabit Ethernet x 1 + USB 3.0 x 3
 - Network adapter
- Form Factor
 - External
- Interface (Bus) Type
 - USB-C
- Ports
 - 41 g
- Cabling Type
 - Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
 - 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
 - 1 Gbps
- Processor
 - VL813
 - USB 3.1
 - White
 - 3-year warranty
 - Network adapter
- Form Factor
 - External
 - USB-C
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - 1 Gbps
 - USB powered, built-in 3-port SuperSpeed USB 3.0 hub
 - USB 3.1
Processor / Memory
- Processor
 - VL813
 - 1 x 1000Base-T - RJ-45 - female , 3 x USB 3.0 - 9 pin USB Type A (power only) - female
- Cables Included
 - 1 x USB-C cable (integrated)
 - Plug and Play, RoHS
 - White
 - 41 g
 - Limited warranty - 3 years
 - 0 °C
 - 45 °C
