This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
Seamless compatibility
Designed to bridge the gap between new and old technologies, the C2G USB 3.1 USB Type-C to VGA Adapter ensures seamless compatibility with PC systems. This feature allows users to connect their modern USB-C devices to VGA display monitors effortlessly, making it an ideal solution for presentations, conferences, and educational purposes. -
High-quality video output
With support for maximum external resolutions up to 1920 x 1200, this external video adapter delivers crisp, clear, and vibrant visuals. The adapter's ability to transmit high-quality VGA signals makes it perfect for video streaming, gaming, and professional applications where image clarity is important. -
Plug-and-Play convenience
Adhering to Plug-and-Play compliant standards, the adapter offers a hassle-free setup without the need for additional drivers or software. This feature ensures a straightforward connection process, allowing users to enjoy an uninterrupted display experience.
 - C2G USB 3.1 USB Type C To VGA Adapter - USB C to VGA White - external video adapter - white
 - External video adapter
- Bus Type
 - USB 3.1
- Max Resolution
 - 1920 x 1200
- Interfaces Details
 - VGA , USB 3.1 (USB-C)
- Enclosure Colour
 - White
 - 3-year warranty
- Bus Type
 - USB 3.1
- Max Resolution
 - 1920 x 1200
 - Plug and Play
 - 32 g
- Enclosure Colour
 - White
 - Limited warranty - 3 years
 - 0 °C
 - 50 °C
