C2G Ultra Flexible High Speed HDMI Cable with Low Profile 0.3m
Quicklinx: D0F2WS00 Mfr#: 82361
Length: 30cm
Select:
£3.43 ex VAT
£4.11 inc VAT
Experience ULTRA HD (4K) displays with this Ultra Flexible High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). The ultra-flexible cable construction and low profile, compact connector design make this cable an ideal fit for installations in tight spaces. This High Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming consoles, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • Flexible design
    The 0.3 m Ultra Flexible High Speed HDMI Cable is designed with a low-profile connector, making it the ideal choice for tight spaces and ensuring a seamless connection between your devices.
  • Enhanced viewing experience
    Supporting 4K resolution, 3D transmission, and Dolby DTS-HD, this HDMI cable with Ethernet enhances your viewing experience by delivering sharp, detailed visuals and high-fidelity audio.
  • Seamless device integration
    Featuring HDMI CEC support, this cable allows for integrated control of compatible devices, making it easier to manage your home entertainment setup without the clutter of multiple remotes.
C2G 0.3m Ultra Flexible High Speed HDMI Cable with Low Profile Connectors - HDMI cable with Ethernet - 30 cm
Cable
Length
30 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI cable with Ethernet 4K support
Length
30 cm
3D-Transmission, HDMI CEC support (Consumer Electronics Control), Dolby DTS-HD support, low profile design
Connector
19 pin HDMI Type A - male
CEC
Limited warranty - lifetime
Length: 30cm
Brand: C2G
