C2G RapidRun[R] 0.5 VGA (HD15) + 3.5mm
Quicklinx: 9NLKWS00 Mfr#: 87115
RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
Ideal for educational and institutional installations, this flying lead sends PC video, 3.5 mm stereo audio and RCA composite audio/video over one cable. It is commonly used on the display end of classroom setups with the corresponding wall plate used at the teacher's station.
  • Versatile connectivity
    Equipped with VGA (HD15), 3.5mm, composite video, and stereo audio flying lead, this cable offers a comprehensive solution for transmitting both video and audio signals. Its color-coded connectors simplify the installation process, ensuring a hassle-free setup.
  • High-quality construction
    The shielded technology of the C2G RapidRun cable minimizes signal interference, delivering a clear and reliable audiovisual experience. Its robust design is tailored to withstand the rigors of frequent use, making it an ideal choice for both professional and home environments.
  • Easy integration
    Featuring male connectors on both ends, including 15 pin HD D-Sub (HD-15), RCA, and mini-phone stereo 3.5 mm, this cable seamlessly integrates with a wide range of multimedia devices. The inclusion of a MUVI connector further enhances its compatibility, offering a straightforward connection to various equipment.
C2G RapidRun VGA (HD15) + 3.5mm + Composite Video + Stereo Audio Flying Lead - video / audio cable - VGA / composite video / audio - 50 cm
Cable
Video / audio cable - VGA / composite video / audio
Shielded
Length
50 cm
Connectors
RCA x 3 - male , Mini-phone stereo 3.5 mm - male , HD-15 (VGA) - male
Connectors (Second End)
MUVI connector - male
Colour-coded connectors
Cable Type
Video / audio cable
Interface Supported
Shielded
Length
50 cm
Connectors
RCA x 3 - male , Mini-phone stereo 3.5 mm - male , 15 pin HD D-Sub (HD-15) - male
RoHS
Limited warranty - lifetime
