C2G HP JD118B-C2G MMF Transceiver
Quicklinx: CHZ5WS00 Mfr#: 89084
This SFP (mini-GBIC) Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD118B. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
HP JD118B
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP 3100, A5120, E4500; HPE 10512, 12504, 1910, 3100, 3600, 3610, 4200, 4500, 5120, 5500, 5810, 5820AF, 5830AF, 5920AF, 7506, WX5002, WX5004; FlexFabric 1.92, 11908, 12902; FlexNetwork MSR3048
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
HP JD118B
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
HP 3100-8-PoE v2 EI Switch, A5120-24G-PoE+ SI Switch, A5120-48G SI Switch, E4500-24-PoE , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-16G Switch, 1910-24G Switch, 1910-24G-PoE (170 W) Switch, 1910-24G-PoE (365 W) Switch, 1910-48G Switch, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-16 DC EI Switch, 3100-16 EI Switch, 3100-16-PoE EI Switch, 3100-24 DC EI Switch, 3100-24 EI Switch, 3100-24 V2 EI Switch, 3100-24-PoE EI Switch, 3100-24-PoE v2 EI Switch, 3100-48 Switch, 3100-8 DC EI Switch, 3100-8 EI Switch, 3100-8 v2 SI Switch, 3100-8-PoE EI Switch, 3600-24 EI Switch, 3600-24 SI Switch, 3600-24 v2 EI, 3600-24-PoE EI Switch, 3600-24-PoE SI Switch, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP EI Switch, 3600-24-SFP v2 EI, 3600-24TP SI Switch, 3600-48 EI Switch, 3600-48 SI Switch, 3600-48-PoE EI Switch, 3600-48-PoE SI Switch, 3600-48-PoE+ v2 SI, 3610-24 Switch, 3610-24-SFP Switch, 3610-24-TP Switch, 3610-48 Switch, 4200-12G Switch, 4500-24 Switch, 4500-24-PoE Switch, 4500-48 Switch, 4500-48-PoE Switch, 5120-16G SI, 5120-24G SI, 5120-24G-PoE+ SI, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5820AF-24XG, 5830AF-48G Switch with 1 Interface Slot, 5830AF-96G Switch, 5920AF-24XG Switch, 7506, WX5002 Access Controller, WX5004 Access Controller , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis , HPE FlexNetwork MSR3048
