C2G HDMI Adapter Ring with Colour Coded - Black
Quicklinx: GQ1GWS00 Mfr#: 84268
£73.19 ex VAT
£87.82 inc VAT
The Patent Pending Universal 4K HDMI Adapter Ring is the perfect addition to conference rooms, huddle spaces, lecture halls or classrooms to make sure that anyone can connect. The standard configuration includes the adapters to connect nearly any device to the in-room display, while supporting up to a 4K video resolution. Standard configuration includes HDMI to DisplayPort, Mini DisplayPort, or USB-C adapters to meet connectivity challenges.
[H]Colour Coded Adapters[/H]
Each adapter is colour coded with a band that saves time and frustration by making it easy to quickly identify the adapter you need.
[H]Integrated Pull Tab[/H]
Easily grab the adapters when you need them with the integrated Pull Tab that is also available to be customized to feature your company or organization logo. Minimum order quantities apply to customized Pull Tabs.
[H]Universal Cable Mount[/H]
The universal cable mount attaches directly to the in-room HDMI display cable, ensuring that the adapters are always within reach. The adapter ring slides to the HDMI connector when needed and out of the way when not in use, reducing strain on the HDMI cable and clutter on the tabletop. The optional stopper fits on HDMI cables from 5mm to 10mm in diameter and prevents the adapters from sliding too far down the cable.
[H]Tools Included[/H]
To simplify the process, installation tools for mounting the adapters and optional stopper are included. The innovative HDMI Cable Gauge Tool reduces stopper installation time by allowing the right-sized stopper insert for the HDMI cable to be quickly identified.
  • Connector 1
    (3) HDMI Female
  • Connector 2
    (1) DisplayPort Male, (1) Mini DisplayPort Male, (1) USB-C Male
  • Colour
  • Warranty
    Lifetime
C2G HDMI Adapter Ring with Colour Coded - video adapter kit - Mini DisplayPort / DisplayPort / HDMI / USB
Cable
Video adapter kit - Mini DisplayPort / DisplayPort / HDMI / USB
Included Qty
3
4K support
Cable Type
Video adapter kit 4K support
Included Qty
3
Interface Supported
Adapter ring
Details
Included Qty x Type
Video adapter - Mini DisplayPort (male) to 19 pin HDMI Type A (female) , Video adapter - 20 pin DisplayPort (male) to 19 pin HDMI Type A (female) , Video adapter - 24 pin USB-C (male) to 19 pin HDMI Type A (female)
RoHS 2 (2011/65/EU)
138 g
Limited warranty - lifetime
Brand: C2G
