The Extender for Logitech ConferenceCam CC3000e extends the camera or speakerphone up to 100 feet away from the system hub. This solution requires two standard Cat5 or Cat6 cables for extension and installation is made easy through labeling and color coding. This extension solution passes the audio and video signals to the Logitech hub, but, when extending the camera, it also passes the control signals. These control signals allow the camera to continue to move as if it were directly connected to the hub with the cable provided by Logitech. This means that full functionality of the CC3000e will be retained at full extension distance. The flexibility provided by this kit adds value and flexibility to the Logitech ConferenceCam CC3000e, making it the perfect fit for almost any application. Note: This extender is designed to extend either the camera or the speakerphone. Two extenders are required to extend both the camera and speakerphone.
Extended reach
The Extender for Logitech ConferenceCam CC3000e significantly enhances your conference room setup by extending the USB connection distance up to 30 m, ensuring optimal placement and performance without compromising on video and audio quality. -
Seamless connectivity
Designed with USB 2.0 compliance, this extender supports high-speed data transfer, making it ideal for maintaining smooth and stable connections during critical meetings and presentations. -
Easy installation
With its external form factor and wired connectivity technology, the extender is straightforward to set up, requiring no additional software or drivers for PC compatibility, ensuring a hassle-free integration into existing systems.
- C2G Extender for Logitech ConferenceCam CC3000e - USB extender - USB 2.0
- USB extender
- Form Factor
- External
- Data Link Protocol
- USB 2.0
- Max Transfer Distance
- 30 m
- USB extender
- Form Factor
- External
- Connectivity Technology
- Wired
- USB 2.0
- 30 m
- USB 2.0
- Cables Included
- 2 x USB Y-cable - 90 cm
