C2G DVI-D M/M Dual Link Digital Video Cable 0.5m
Quicklinx: B8F3WS00 Mfr#: 81187
Select:
This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed digital video transmission up to 9.9 Gbps. 28 AWG copper conductors are individually insulated in foam-polypropylene to minimize crosstalk, and ensure high speed, error-free transmission.
Tri-shielded undermold with dual foil shield and braid shield protects against unwanted EMI/RFI interference. Gold-plated contacts provide full conductivity with no data loss. PC and Mac compatible cable supports hot-plugging of DVI display devices. PC-99 color-coded: white.
Does not support analog video; only supports digital video signal.
  • High-quality connectivity
    Featuring a 24+1 pin digital DVI interface, this DVI-D M/M Dual Link Digital Video Cable ensures a reliable connection between your devices. Its gold-plated connectors provide superior signal clarity and protection against corrosion, making it an ideal choice for both Mac and PC users.
  • Enhanced durability
    Constructed with a 28 American Wire Gauge (AWG) and shielded by dual foil with braid, this cable offers robust protection against external interference. The triple-shielded technology further enhances its durability and ensures a stable signal transmission for high-quality video output.
  • Versatile compatibility
    Designed to support a wide range of devices, this cable comes equipped with male connectors on both ends, making it easy to connect digital DVI-compatible devices. Whether for gaming, presentations, or watching high-definition content, this cable delivers a seamless experience.
C2G DVI-D M/M Dual Link Digital Video Cable - DVI cable - 50 cm
DVI cable
Triple shielded
Length
50 cm
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
DVI cable
Triple shielded
Shielding Material
Dual foil with braid
28
Plated Connector
Gold
Length
50 cm
Connector
24+1 pin digital DVI - male
