Plug in the power extension cord to make your work environment more flexible and efficient. The female connector plugs directly into device, and the male connector plugs into an existing cable. This heavy-duty 16 AWG cord features a fully molded design for maximum durability and long life. Compatible for monitors, scanners, printers, and other devices that use a 3-pin shroud power connector.
- C2G - power extension cable - power IEC 60320 C13 to IEC 60320 C14 - 1.2 m
- Power extension cable
- Length
- 1.2 m
- Connector
- Power IEC 60320 C13
- Connector (Second End)
- Power IEC 60320 C14
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 16
- Rated Voltage
- AC 250 V
- Length
- 1.2 m
- Black
- Connector
- RoHS
