C2G 91.4M VGA Over CAT5 BOX TX (300FT)
Quicklinx: D0FGWS00 Mfr#: 89362
Extend a video signal up to 100m at 1920x1200 resolution.
The VGA over Cat5 Box Transmitter, when used in conjunction with a receiver, allows you to extend a VGA signal over a Cat5/Cat5e/Cat6 unshielded twisted pair cable up to 100m without signal degradation at 1920x1200 or 1920x1080 resolutions. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. The transmitter and receiver come in either wall plate or box form factors and are interoperable allowing you to choose the form factors that are best suited for the application. In addition, this solution utilizes phantom power providing you the flexibility to power at either the transmitter or receiver end.
The EDID copy feature ensures compatibility with any monitor. Built-In power surge protection and high ground loop immunity ensure high performance signal extension.
  • High resolution support
    The VGA over Cat5 Box Transmitter by C2G TruLink supports a maximum video resolution of 1920 x 1200, ensuring clear and detailed visuals for PC compatibility. This feature is suitable for high-quality presentations and video streaming.
  • Extended reach
    With a maximum transfer distance of 100 m, this video extender allows for flexible placement of your display equipment. It's perfect for large conference rooms or educational settings, ensuring that the signal reaches even the furthest projector or monitor.
  • Easy connectivity
    Featuring both HD-15 and RJ-45 female connectors, the device ensures a hassle-free setup. It supports VGA for video and network connectivity, making it a versatile solution for extending your video signal over long distances.
C2G TruLink VGA over Cat5 Box Transmitter - video extender
Video extender (transmitter)
External
Transmission Medium
CAT 5
Max Transfer Distance
100 m
362 g
1-year warranty
External
Wired
Max Resolution
1920 x 1200
100 m
1 x VGA - HD-15 female , 1 x network - RJ-45 female
1 x VGA cable
External power adapter
362 g
Limited warranty - 1 year
