C2G 91.4M VGA Over CAT5 4-PORT BOX TX(300FT)
Quicklinx: D0FJWS00 Mfr#: 89364
Extend a video signal up to 100m at 1920x1200 resolution.
The 4-Port VGA over Cat5 Box Transmitter, when used in conjunction with receivers, allows you to extend a VGA signal over a Cat5/Cat5e/Cat6 unshielded twisted pair cable to up to four connected monitors and up to sixteen monitors by daisy-chaining receivers. This system can extend a signal up to 100m without signal degradation at 1920x1200 or 1920x1080 resolutions. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. The receivers (not included) come in either wall plate or boxes and are interoperable allowing you to choose the form factors that are best suited for the application. In addition, this solution utilizes phantom power providing you the flexibility to power at either the transmitter or at each receiver.
The EDID copy feature ensures compatibility with any monitor. Built-In power surge protection and high ground loop immunity ensure high performance signal extension.
C2G TruLink VGA over Cat5 4-Port Box Transmitter - video extender
Video extender (transmitter)
Ports Qty
4
External
Transmission Medium
CAT 5
Max Transfer Distance
100 m
460 g
1-year warranty
External
Ports Qty
4
Wired
Max Resolution
1920 x 1200
100 m
1 x VGA - HD-15 female , 4 x network - RJ-45 female
1 x VGA cable
External power adapter
460 g
Limited warranty - 1 year
