Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
 - C2G - serial extension cable - DB-9 to DB-9 - 5 m
 - Serial extension cable
- Technology
 - Shielded
 - Molded, thumbscrews
- Length
 - 5 m
- Connector
 - 9 pin D-Sub (DB-9) - female
- Connector (Second End)
 - 9 pin D-Sub (DB-9) - male
 - Black
- Technology
 - Shielded
- Length
 - 5 m
 - Black
- Connector
 - RoHS
