C2G 4m USB 2.0 USB C to USB Micro B Cable M/M - Black
Quicklinx: CHNNWS00 Mfr#: 88853
Length: 4m
£16.89 ex VAT
£20.26 inc VAT
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 4 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Lifetime warranty
    Length: 4.00 Meter
  • Warranty
    Lifetime
  • Colour
  • Length
    4 meter
C2G 4m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - Micro-USB Type B to 24 pin USB-C - 4 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
4 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
4 m
Connector
24 pin USB-C - male
USB / USB 2.0
Length: 4m
Brand: C2G
