C2G 3m USB 2.0 USB C to USB A Cable M/M – Black
Quicklinx: C3R5WS00 Mfr#: 88872
Length: 3m
Select:
£19.54 ex VAT
£23.44 inc VAT
This USB 2.0 USB-A to USB-C cable is the perfect solution for connecting a smartphone, tablet, or other device with a USB-C port to a computer with the standard a USB Type-A port up to 3 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for syncing and downloading pictures or uploading new apps, as well as 5 volts and 1 amp of power for device operation and charging. The USB-C connector has a robust design allowing for the connector to be plugged in and un-plugged up to 10,000 times; six times more connection cycles than traditional USB A connectors. Additionally, the USB-C connector is user-friendly has a symmetrical design which is identical on both sides, meaning it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time, whilst preventing damage to the connector port. The colour coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Colour
  • Warranty
    Lifetime
  • Length
    3 metre
  • USB 2.0 Type-C Connector
    Male
  • USB 2.0 Type-A Connector
    Male
C2G 3m USB 2.0 USB Type C to USB A Cable M/M - USB C Cable Black - USB-C cable - USB to 24 pin USB-C - 3 m
USB-C cable
Double shielded
Molded, sync and charge, nickel plated shell
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
Double shielded
American Wire Gauge (AWG)
24/30
Length
3 m
103 g
Connector
24 pin USB-C - male
USB / USB 2.0
Length: 3m
Brand: C2G
