Experience ULTRA HD (4K) displays with this High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This high retention cable is equipped with gripping connectors which provide 3 times greater port retention than standard HDMI connectors, ensuring that your devices maintain signal over longer periods of time without interruption. This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is back by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
 - C2G 3m High Speed HDMI Cable with Gripping Connectors - HDMI cable with Ethernet - 3 m
- Cable
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 30
- Length
 - 3 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - 4K support
 - Limited lifetime warranty
- Cable Type
 - HDMI cable with Ethernet 4K support
- Technology
 - Shielded
 - 30
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 3 m
- Plated Connector
 - Gold
 - Gripping connectors
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - CEC
 - 426 g
 - Limited warranty - lifetime
