C2G 3m Cat5E 350 MHz Snagless Booted Patch Cable - Pink
Quicklinx: 69P9WS00 Mfr#: 83620
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance for both home and office networks.
  • Durable design
    Designed with a PVC jacket and an American Wire Gauge (AWG) of 24, this network patch cable is built for durability. Its robust construction ensures it can withstand the rigors of daily use, making it a reliable choice for connecting a wide range of devices.
  • High-speed performance
    With a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for various networking requirements. It's ideal for applications requiring fast connectivity and minimal data loss.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - pink
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Pink
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
Pink
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
